Hi,
I wanted to make my own SSD mount using 90degree angled aluminum (it will be mounted behind the mobo tray). I'm looking for a springloaded bolt or something like this:
but SSD mounting hole sized, so really really small comparatively.
Basically, I have a Define R4 case, and I wanted to use the "brackets" im making instead of directly mounting the SSD's to the holes in the mobo tray, and using somekind of springloaded pin system to secure the SSD to the bracket itself. I'm trying to copy the bracket idea from "the Define Project" case mod log, and here's a pic of what i wanted to do:
but with the spring loaded pin on the side holes to secure the SSD to the bracket instead of having to use actual screws there (the brackets will be screwed/bolted to the mobo tray).
Thanks!
-kert
Thanks!
-kert
