Okay, all my gear is in the sig. I am going to attempt 5ghz this weekend. Generally speaking, what are the settings/ranges I will want to be in in order to hit 5ghz? I have g skill sniper 1600 ram (o.c. to 1866 at 1.35v) but Im thinking that turning it down to 1333 or at least 1600 will take some stress off the chip? Im at ultra LLC now, so Im making the assumption that Extreme will be required off the bat, is that wrong? Also, will disabling internal PLL over voltage add to the probability of success?
Current clocks:
hyper threading on
offset -.010 at 4.5ghz (1.34v on load)
ram at 1866 o.c. from 1600 (1.35v and 10 10 10 25 timing.)
h-50 with 2 yate loon 2k rpm fans in push pull hitting mid 70's on load. (although I will have a couple big fans on full blast for these benches)
Current clocks:
hyper threading on
