1 - 6 of 6 Posts
i am wondering which psu is better for v354b case.
this is my system:
asrock a75b-hvs mb
a8-3850
1 bluray
2 hd
later i will install a video card (ati 6xxx or ati 7000) and some more hard drive
will 450 psu be enough for all those thing including the video card & hd or not? or i need to buy bigger one.
this psu i will buying soon:
Antec VP-450 450W ATX 12V v2.3 Power Supply
or get
Antec BP550 Plus 550W Continuous Power ATX12V V2.2 80 PLUS Certified Modular Active PFC Power Supply
ur links doesnot work at all. it send me back to the newegg home page.
that is expensive psu. i dont need that much anyway. i think 650w psu will be fine i think.
Are you going to install a APU crossfire card or just a normal higher powered card?
If you're going for crossfire, the max is a 6670 and that does not use any more power than the PCI-e slot requires.
There is no reason to buy an 850W PSU for a build like this.
I run my whole system (6670, 3850, 4HDDs) off of a 350W PSU. Now you have to make sure it is a good model. I use seasonic and they are one of the best in the business.
Definitely run modular with that case.
1 - 6 of 6 Posts
