1 - 6 of 6 Posts
Not a very experienced overclock-er especially when it comes to tinkering with the voltage.
If i increase the core clock over 100mhz , any game will crash after 45-60 mins.
100Mhz is fine , i am looking to go way above using msi afterburner.
My temps on load 4k Ultra gaming goes to maxxx between 44c- 48c .
Please advise on the best overclocking settings.
every gpu is different and is there really a safe OC that will never harm your gpu?
some brands will not honour a warranty! You are at your own mercy
you have almost answered this question yourself
at average 45c temps i could push the card to more results , i just need help doing so .
Anyone?
Download GPU-Z and check your ASIC quality. You may have lost out in the "silicon lottery" my Gigabyte G1 Gaming 980Ti has a 72% ASIC and is only truly stable @ +112 Core & +334 Mem. w/ max card temps, on air mind you, hitting around 65C I can push it beyond that if i bump up the mV but for the moment I'm happy where it is until I get my water cooling loop done.
Originally Posted by whitrzac View Post
I have an evga classified that failed the lottery. Even on water it will not hit 1500 stable with stock voltage.
I'm kinda in the same boat. I have two EVGA 980ti's - one an ACX and the other a hybrid, and I can't add more than 75mhz on the combo without locking up after 40 minutes or so. Asic is 68 and 73 respectively. Funny thing is before SLI I was adding 130+ core to the ACX card on its own, no problem, stock voltage, but once I added the hybrid it was game over (literally). I tried upping the hydro's voltage separately (with the higher asic it, obviously, was running a lower stock core voltage) but that didn't work so well and I just gave up.
1 - 6 of 6 Posts
