1 - 20 of 55 Posts
· Premium Member
I will be upgrading to Sandy Bridge soon
, so I had some time to kill and decided to spend it on live chat with an Intel technician asking about max voltages, the conversation went as follows:
Please wait for a site operator to respond.
You are now chatting with '****'
****: Hello. Thank you for using the Intel Customer Support chat service. We are glad to be of service. How can I help you today?
[email protected]: Hi
****: welcome
[email protected]: I have purchased an I5 2500K
[email protected]: And I was wondering what the maximum voltages are on air cooling?
****: do you mean the RPM?
[email protected]: No I mean the Vcore
****: ok
****: this is the main page of this processor:
****: Intel(R) I5-2500K:
****: now let me gather that information, please wait
[email protected]: Just to clarify, I mean what are the recommended safe voltages for 24/7 use?
****: The range should be Minimum 0.25 volts and Maximum 1.52 volts
****: You can confirm this information at the following url:
****: http://download.intel.com/design/pro...hts/324641.pdf
****: Page 78
****: Is there something else I would be able to assist you with?
[email protected]: So it is safe to use my CPU at 1.52V 24/7?
****: yes sir, it will very important if you are going to use 1.52 volts, the ram should work with no more than 1.5 volts as well, if you use ram with more than this voltage the processor memory controller could be damage
[email protected]: So it's safe to use as long as I keep my RAM voltages bellow 1.5V?
****: correct, you may use 1.5 without issues
[email protected]: Thank you, that is all my questions.
Looks like Intel have created indestructible silicone at last!
· Premium Member
Originally Posted by badatgames18
HAHAHAHHAHA finally some friggin proof that i am not ruining my chip!! ATLAST.
max load temps on my rig is 59-61C on IBT... so i still don't suggest upping vcore to 1.5 24/7 on air
Nice temps, and nice OC.
· Premium Member
Actually according to some people its still not good enough. Even without this proof I came to my own conclusion that it will be fine (even though i got flamed for it) but +rep to for confirming this yet again
EDIT: overclocker would you mind if I linked this thread to op of 'Sandy got Stable Club'?
· Premium Member
Originally Posted by overclocker23578
Go for it!
Thanks
Originally Posted by fluxlite
At 1.52v with this cooler I'm pretty sure my cpu would be hotter than the surface of the sun.
If I took it 1.52 as a maximum I could proberbly get my cpu to 5.3ghz stable. and keep my temps below 80c
A near-identical conversation with Intel Support has been posted before. I'm sorry but unless you're speaking to an engineer, they probably know no more than you do reading a spec sheet... I'm not here to claim I know any more, but I feel as if you're speaking to average-joe tech support.
That said, I'm sure you could use that convo to your benefit if you destroyed your chip and requested an RMA.
Does anyone know of anyone who's actually damaged or destroyed their 2500k from excessive heat/voltage?
Pretty sure thermal throttling would kick in and stop the chip from cooking itself compeltely. You'd obviously still run the risk of long-term degredation, though.
· Iconoclast
Agreed.
Originally Posted by snelan
Does this mean I can run at 5GHz at 1.536 VCore because I am on water?
You can run it however you like.
Is it safe? Let us know in a year or two.
1 - 20 of 55 Posts
