Max save NB voltage?
352 8
So I'm testing what FSB I can max boot on.
I'm currently at 1950 (487) with 1.393v (if I recall correctly).
I have two more options to choose from-- something like 1.5v and 1.9v.
So is it safe to set the max voltage on the NB? The NB is currently 30c with watercooling.
So should I up the voltage just to see how high I can post or can I keep it at the highest voltage?
1 - 9 of 9 Posts
ouch, 1.9v for nb? sounds a little painfull if you ask me :/ i would say keep it under 1.7v since you have it under water and itt'l stay nice and cool :]
max voltage should be fine for a suicide run /test to see how high ittle post
My bad!
I'm currently running 1.563v
I made the same mistake in the OP, I'm on 1.5v and I want to know if 1.7v is safe for 24/7 use?
Originally Posted by dralb View Post
Generally, 1.5v is the limit for NB. this is all dependant on temps, though.
I'm on water and non of my temps (CPU, GPU or NB) break 40c.
So 1.7 is for SR and testing only?
Originally Posted by Zippit
bumperty bump
yea I'm gonna have to agree 1.7 is a lot. If your temps are okay and everything is running right then you should be fine, I presume. Although, 1.5 is max recommended....but that's probably on air. I would think it wouldn't last a long though? anyone agree?
lol off topic: whats that ocn as5 thing in your sig mean?
1 - 9 of 9 Posts
