So, doing the last bit of ordering for my water cooling setup, rads. This is for my sig rig. Using EK CPU and GPU blocks. Using at least one 655 pump, might go two in series.
My question, what rads would be best to maximize cooling with relatively low fan speed/noise? Planning to run corsair SP high performance on a fan controller so I have some performance headroom for benching if needed. Not looking for silent, just a low hum in most situations normal situations. Current thought is Alphacool UT60's. A pair of 480's top and bottom and maybe a 240 in the basement as well. Leaving front open to pull in fresh air. Cross flow in the bottom if I do two rads. Exhaust out top and back of case.
Not overly worried about the cost of the rads, but dot want anything outrageously expensive. Don't want monsta rads and prefer push fans only.
