Originally Posted by TerminatorXT
I see you favor CPU-Z over the BIOS
thats kinda weird, because the BIOS sets the voltage
How long should my overclock be under Prime95 before its considered stable?
It's not that I favor it, but it's that it's showing the actual voltage that is running through the CPU. There are 2 things you will notice, both of which are very normal and are an intentional design:
- vDrop: this results in the voltage that you'll see when the system is idling.
- vDroop: this results in the voltage you'll see when the CPU is under full load.
Regarding stability, this will come as a shock. But don't worry because it's actually quite easy. I'll start with Prime testing. If you have the 64-bit version of Windows 7, then use the
64-bit version of Prime95. If you have the 32-bit version of Windows 7, then use the
32-bit version of Prime95. To close Prime95 all the way when you're finished, right-click on its icon in the System Tray/Notification Area and choose "Exit".
- 12 hours of the Small FFTs test.
- 12 hours of the Blend test.
- 12 hours of the In place large FFTs
Then there's linpack testing. For that, I highly recommend
LinX. Here's how I recommend using it (it's very similar to what its Read Me says):
- Begin from fresh boot.
- Click the button that says "All" next to where it shows the amount of memory to use.
- If you have the 64-bit version of Windows 7, then make a mental note of how much memory it chose, and then un-click the button and reduce it by 10 MB at a time (or more) until the test starts. I was able to use 3400 MB. See how much you can get it to use!
- If you have the 32-bit version, then you don't need to worry about it.
- Set it for 100 runs.
- Start the test.
- Be aware that this test will get the CPU about 10-15°C wamer than Prime testing. It will also heat up the memory a little more too.
Then there's
Memtest. This doesn't stress the memory, but instead, it can reveal errors. The best way to use Memtest is to just run it and let it do about 10 passes. 1 pass is when it completes all 8 of its default tests.
There are other little things you can do, but damn: if it can do all of this, then you know it's stable.
If you want to make all of this easy, then do each test while you're sleeping. Besides, it's best to avoid doing
anything with the computer while each test is running.
