Maximus 2 Formula
495 Views 5 Replies 4 Participants Last post by  o4xa
I have a maximus 2 formula and when i turn it on it reboots 2 times and on the 3rd time it just has the fans running, dvd and hdd all turn on as well, the motherboard will not post no matter what, i have tried to see if it is a ram issue and it is not, can anyone help?
1 - 6 of 6 Posts
Does that board have the LCD poster like the original Max Formula? If so what does it stop on?
It does come with a LED poster.
Could be a defective motherboard.
Did you try testing out the memories? Using each stick on each slot?
yes it does have a lcd screen, it says power off, yea i have also tried 1 sick of ram in each slot.
I'll be watching this thread as i'm having the exact same problem. Could be a bios problem try using a old cpu and update the bios for wolfdale support. I don't have access to a old cpu or i'd try it myself.
I have been using a wolfdale since day 1 e8200 to be exact, never touched the bios though, was not even overclocked this time
1 - 6 of 6 Posts
