1 - 6 of 6 Posts
Hey all. I received a free i5-750 CPU from my uncle that works at intel. I bought a Maximus III Gene motherboard. I installed everything correctly with 2 Corsair Vengeance 1600 RAM in both red slots...
It won't POST.
It turns on for half a second and shuts off for 2 and repeats. I tried using MemOK! feature with a no-go. I used the ROG Connect to find out there is a "CPU Initial" error....
Board revision is 1.00G
Can anyone help?????
Has anyone with the same board had this problem???
Leader of the #1 [email protected] Team
The Mobo, RAM, or CPU is bad. OR their not Compatible. Maybe the PSU isn't enough.
Originally Posted by tx-jose View Post
get another cheap motherboard and test out the CPU.......
Yeah you could try that, kinda forgot to mention it lol
Ok I'll try getting a super cheap motherboard. Just wondering, the Corsiar Vengeance RAM are compatible with the 1156 platform correct? Plus I've noticed that when I unpluck the CPU power connection, and turn the power on, the motherboard actually stays on, just no video output.....kinda weird
Any other ideas?
semi-legit
Put them in DIMMS 0,1 (black slots) and give it a shot, if you flip through the manual I believe it indicates you must use these if only using 2x modules.
1 - 6 of 6 Posts
