1 - 4 of 4 Posts
ლ(╹ε╹ლ)
I'm running a 6600K, 7870K and MSI GTX 970 off a HCP-1300 and wondering if I can run it without a fan.
My rig pulls around 600 watts from the wall under full load (both processors and graphic card at 100% load),
I'm assuming it's fine, but I just want to check what you guys think
ლ(╹ε╹ლ)
Discussion Starter #4
Originally Posted by Clausius View Post
I would say no. I have a OC'd 4670k and a 760 which will thermal throttle when under load without fans.
I would say me system is well spec'd in the cooling department.
that's not what I'm asking at all. I want to run my power supply without a fan.... A 1300 watt platinum PSU will basically give out no heat under the load I'll give it.
1 - 4 of 4 Posts
