1 - 4 of 4 Posts
im thinking about getting a second 7800gt and i have one maze4 block. Now do i need to get two of the slim style or will i be able to have enough space and get another regular one? It looks like it would be close. Its the acetel version so the top is plastic so if it rests on it it wont short anything. Anyone have factual knowledge on this??
I would get another standard block. I ordered the "low profile" sli kit and sent it back after I found that putting ram sinks on would get in the way of the tubing.
SNERP!!!
I say get the regular one. You should have enough space.
have you thought of buying one slim one and using the full size one as well? put the full size one on the bottom card, and the slim one on the top card (so the slim one goes in between the two cards)
1 - 4 of 4 Posts
