1 - 6 of 6 Posts
Originally Posted by ThisisGeorge;11646976
Cool video, doesn't really prove anything. Since each hit was not the same for either laptop.
Yeah that's why I used a strength test holding the laptop by the LCD assembly, so you can see how the hinges hold up. I did the tapping out of request, not really my idea.
Your face doesnt prove anything either
I fix dell's for a living.. the hinges are strong on the e6500... the bottom base that the hinges slide into... is not
Discussion Starter #6
Interesting, I've taken the Dell E6500 apart completely, I'd say it's stronger then the almost non existent "base" on the MBP, and just about every consumer laptop, and even equal's the Thinkpad's hinges. I've even used it for several times without any screws on the hinges while disassembling.
Hmm weird that you'd say the base was weak, it's cast magnesium alloy, pretty thick too.
You can see a quick disassembly guide I did and posted on Ifixit.com
http://www.ifixit.com/Teardown/Dell-...eardown/4398/1
Here's a pic:
1 - 6 of 6 Posts
