Pump starts up fast and then slows down. I just started to move my whole setup to a new case... I filled up the loop with water started the leak test and noticed the pump would run fast and then slow down once being turned on. Pump was working fine as of 12 PM this afternoon and all weekend as I left the PC folding.
I just realized I had the pump on it's side while I was test fitting tubing in my case... Could that have killed the pump? It shouldn't have affected it since I'm sure when it's delivered or in transit it gets tossed around and it wasn't running or had water in it... I'm a bit stumped at the moment...
