Media player 10
684 9
Getting audio but no video playback( just a black screen ). Tried reinstalling WMP10 only to find the same problem....any suggestions?
1 - 10 of 10 Posts
Linux Guru
is it currently in skin mode? if so that may be the problem, so take it out of skin mode.
you may also want ot right-click on the black scrren in now playing while it is playing, then click on show video.
Linux Guru
Sorry, forgot to mention it many problem happens in streaming video also
Ok here are the possibilities, you codec may be wrong, but relaoding shoudl have fixed it. You file may be a video file, but not have video attached.
what I recommend you do is completetly uninstall WMP10 and after you restart your system try to install it again.
and not to point a finger, but are you in the Now Playing Tab?
I am using the now playing tab and i am not able to unintall the program because there is no uninstaller with the software....ie no uninstaller in the program files nor in add/remove programs list. Should i uninstall sp2 and reinstall it( dont really want to do that).
Linux Guru
Just turned down the video accel setting now it works...not sure y i mean im using a 9800 pro...not idea...i hate microsoft
great catch in resolving the issue, who would have thought that it wouldn't work with your Vid at full power.
1 - 10 of 10 Posts
