I have all of the fans on your list. While I haven't tested them rigorously yet, I
did test them informally.
Gentle Typhoon 1850 - D1225C12B5AP-15. 9-bladed fan. 1839 rpm. At 3652 MHz, idled at 690 rpm, 42.5 dBA, 35/24c. With LinX running: 1772 rpm, 49 dBA, 70(71)/59c.
Scythe S-Flex SFF-21G 1923 rpm. I believe these fans are identical to the Thermalright TR-FDB series. At 3652 MHz, idle 672 rpm, 42.5 dBA, 35/25c. LinX: 1824 rpm, 53.5 dBA, 69(71)/58c.
Nexus D12SL-12 Real Silent Case Fan, Basic Series. 1138 rpm. At 3652 MHz, idle 581 rpm, 40.5 dBA. 38/28c. LinX: 1130 rpm, 42 dBA, 76(77)/64c
The temps are average core temp(max core temp)/ihs sensor temp. On the i7 860, the ihs temp should not exceed 72c.
The sound levels were taken at 10cm, so subtract 20dB to get SPL at 1 meter. Ambient temps were around 18c.
HTH.
