I purchased a WC loop on the classifieds, i know it may not be the best set-up but i want something to get into WCing
here is the description
i want to know how this will perform, i will probably upgrade to a full 1/2 ID tubing, and slowly upgrade over time, i want some experienced WC'ers to tell me 'calibre' this loop is, is it better/worse than a megahalems/ corsair h50?
thanks
EK Supreme: With clear and black acetal top, can be mounted on 775, 1156 and 1366, amazing block. Corsair Laing D4: Bit noisy, but has very good flowrate and plenty of head, comes with sleeved cable. Swiftech Micro-Res V2: Has some stains on the inside, overall good condition, comes with mounting equipment. XPSC RS240: Some bent fins and scratches, still cools very well and makes a great reservoir for fitting in most cases, will come with 2 sleeved Zalman ZM-F3 fans! 3/8" ID - 1/2" OD Tubing: Grey/UV Blue, Feser made, very good quality, about 2m worth cut into segments. Collection of Phobya Compression fittings: Nickel and Silver, 4 x 45 degree, 4 x straight, some scratches from wrench, fits above tubing. |
thanks
