mem slows down
206 Views 1 Reply 2 Participants Last post by  shemer77
here are some pic of my bios. when I try to run above 1800 fsb my mem goes down >1600. on a mild O/C like 1850fsb mem goes to 1598mhz and it always an odd number. Im semi new to O/C so any tips would be great so I can get this to 2000mhz fsb. also my core load temps are fine all under 60c but my mcp run @ 75+.
1 - 2 of 2 Posts
From what I have learned I think your voltage is changing for your mem so that would probably cause it. When you overclock your cpu you need to make sure you underclock your memory so that it does not cause any mem problems. Then once you got cpu stable, up the memory.
1 - 2 of 2 Posts
