1 - 6 of 6 Posts
I need an experience mem expert needed. I have a i7930 with this mobo:
http://www.newegg.com/Product/Produc...-665-_-Product
I'm trying to stay on budget with 150-175 for memory. I don't know if lower are better or 9-9-9-24 for example is better so here are my choices:
http://www.newegg.com/Product/Produc...82E16820231335
http://www.newegg.com/Product/Produc...82E16820145236
http://www.newegg.com/Product/Produc...82E16820226030
http://www.newegg.com/Product/Produc...82E16820145222
Or you have other options that are not on here let me know. Thanks alot OCNation
semi-legit
I'd either go for the Black Line's or the PIs.
With the the advent of the integrated memory controller, frequency > latency; however the CAS 7 sets are the same price or less anyway.
You'll also be able to OC them pretty well just by loosening the timings up
Reactions: ktrizzle
g skills or munshkins the lower end corsair stuff doesn like clocking much
Reactions: ktrizzle
Super Moderator
I'd go with the PI series for price/performance those PI series OC very well and the Corsair doesn't have good times.
The Mushkin Blackline and the Gskill PIs look Excellent.
I personally own a 3 Gigs kit of Mushkin Blackline 1600 8-8-8-24 @ stock and it overclocks very well, also low voltage, so I can recommend it based on my personal experience (also, the blacklines you're looking at are better than mine so you're supposed to get great performance) but the Gskills look very good too.
I dont think the Corsair can really match those two
1 - 6 of 6 Posts
