1 - 9 of 9 Posts
hi. i have an older pc that i use to surf the web... it has win 2k pro, amd duron 1.2 and 512 mb pc133 of ram. sometimes when im using it the screen goes blue and says beginning dump of physical memory ...what is it?? and what do i do when it happens i just hold the power button till it shuts off
thank you, charbs
A memory dump will save what is in your memory so a programmer can find out why your computer crashed later.
it should also give you an error code or a string you should check what the error code or string means at microsofts support website
Run memtest on the PC see if your memory modules are playing up
Discussion Starter #7
it doesnt do it that often and i never really looked at the code
Originally Posted by charbs152
ok where can i get a mem test prog
thanks for the replies
Here you go mate: http://www.memtest86.com/
1 - 9 of 9 Posts
