1 - 8 of 8 Posts
That ram in my opinion will not be great.
Phenom II's prefer tight timings and High NB clocks and not bandwidth.
Cas 6 1333 or Cas 7 1600 would be much better
you will most certainly run the ram @1333 since thats what these amd builds like (someone correct me if that has changed) so i would do some research which rams do the best at these freq.
the ones i have are great but ive seen a lot with problems getting them stable at the rated timings.
the viperII looks great;D
No. If you like Crucials get these. Always read customers reviews, they do help even if some of them are bad, as in DOA. If you sell 1000s of sticks and one or two come DOA it's no big deal, there will always be DOA sticks once and awhile from any manufacturer.
http://www.newegg.com/Product/Produc...82E16820148334
Although I like these better, 6 CAS.
Customer review.
Pros: This is extraordinary DDR3! I have not seen any kit anywhere for any price that beats the 6-8-6-24 timings @ 1600MHz of this Mushkin Enhanced Redline. I've tested it in a couple of my rigs and everything seems to love it! Crazy-fast, almost brutally-fast. I've been waiting to see something come along in DDR3 that clearly stands out above the crowd, and this is it. It costs only slightly more than many 4GB kits (and less than others), and the specs as well as the performance are eminently worth it. If you want the absolute best, hit "Add to Cart" now.
http://www.newegg.com/Product/Produc...82E16820226120
1 - 8 of 8 Posts
