Originally Posted by yick
with my motherboard i can adjust each timing by half points and adjust the memory speed in steps or i can use profiles
I'm not sure I understood your first question/post.
If you were asking how to lower your memory frequency then that's what I was already talking about in my previous posts.
If, on the other hand, you were asking if it's ok to lower your memory frequency to that of your cpu then you should know that AMD systems get more performance when memory timings (CAS, RAS etc...) are tighter (meaning their numbers are smaller) than when you increase memory frequency. So I'd say you should lower your memory speed/frequency to match your cpu's as this will allow you to tighten memory timings further more (from something like 3-3-3-8 to 2.5-3-3-6 for example).
