1 - 20 of 116 Posts
Discussion Starter · #1 · (Edited)
Hello everybody
I am just making a very light tutorial with a collection of custom config files and a DOWNLOAD LINK for TM5 v0.12
anta777 absolut config *Official* Intel DDR4 24/7 Memory Stability Thread
None of the work is mine but it seems like a pretty good and fast testing app
1/ Extract to a location of you choosing using 7zip or Winrar or similar. No renaming or moving required
2/ Run TM5.exe. All files are now English thanks to @Hequaqua for his idea (y) and [email protected] is the default
3/ To change to a different config file is super easy. On the bottom right of TM5 it says "load config and exit" where you can select the config file required from the location you extracted everything to and it does the rest for you :) The next time you run TM5.exe the new config file will be the default
1/ Extract to a location of you choosing using 7zip or similar
2/ You should see a TM5.exe and a bin folder
3/ Open the bin folder
4/ Rename the chosen .cfg file to MT.cfg (you could remove all the .config files to another location and copy just the one you want to the bin folder and re-name it MT.cfg)
5/ Go to the TM5.exe and click it. TestMem5 should start to run
6/ If you want to change to a different .cfg file you must re-name it MT.cfg and delete the Cfg.link file that was generated in the bin folder when the TM5.exe was executed
7/ I suggest extracting a new instance from the TestMem5 v0.12 (best configs).zip and starting the process again from the top after renaming the first extracted folder to something else
8/ If you want to just change the config file in the first one you extracted you must delete the Cfg.link file that was made during the first execution
9/ Be sure to close everything else when running this
10/ There is a button above the "Exit" button called "Load config & exit" that is supposed to delete the Cfg.link file and exit the program instead of doing it manually
If TM5 doesn't work @Hequaqua suggests running it as admin
Another issue I found is you may have to set Page File Size in Advanced System Settings
Text Colorfulness Line Font Azure
KedarWolf thinks the default MT.cfg and 1usmus_v3.cfg tests might match these error numbers but the other configurations might not, so you might have to do some homework
Here is his post
Error 0 refresh stable error = voltage cutoff choke
Error 1=Simple Test 16mb ~ can be voltage related, can be tRFC issues,
tiny timeout issues for example tRRD_L looks like a bit awkward
Error 2, 12 is a timeout issue, somewhere something ends too quickly or you lack voltage and cells are not recharged in time
a sync issue with other words which's first culprit is voltage somewhere or resistance somewhere
Error 3 & 4 by checking the MT.cfg - are MirrorMove errors
That set shows tRFC 2 issues and this tRFC "auto predicted" ? is wrong.
tRFC is so far always even
as tRFC stepping are 32,16,8,4,2 ,
Error 5 then 6 is a timings missmatch between dimms (data mirror move)
Error 6 is purely related to the IMC , be if procODT, CLDO_VDDP or vSOC
~ it translates to "i couldn't even start transfering data, i crashed"
4-6x error 6 result in full bluescreen
Error 7, 11 are burst tests
  • it will error out if if CAD_BUS is not optimal
  • will error out if tRFC is too low
  • mostly errors out only after time
Error 9 burst test 4mb is a voltage stability issue
If you've lowered tRP , increase vDimm a tiny bit
If you've increased tRP to longer delay, decrease vDIMM +0.01 , one tiny step
Error 10 mostly affects the first 5 main timings
- noticed it can be tRCDWR to RD. can be tRP too, but it also can be the last two tRDWR & tRDRD which don't play well with your main tRCDWR/RD
Error 13 = Simple Test 64mb, timeout while transfering big data
= full crash, nearly always related to voltage ~ as memory was not able to autocorrect it
Error 14 we know is MirrorMove Omb, a timeout issue
- it can error after the 2nd or 3rd pass if something is off my some ns and just "got lost"
Thanks to @KedarWolf for this information (y)
@KedarWolf
To change the language to English, edit the .cfg file and change Language=1 to Language=0
When using usmus .cfg you want to change to 25 cycles. Takes like 3 hours. The default 3 cycles not near long enough
Thanks to @Hequaqua for the idea to make to download set to english
Thanks @h610er for the tip to get [email protected] anta777.cfg to work by resizing the window with his very first post on OCN (y) Memory Testing with TestMem5 TM5 with custom configs
Thanks to all the people that contributed to this software
If you would like something added to this section leave a comment in the thread with @munternet after it :)
Why is this program needed.
Well, I think you know what the program is about, after all, version 5. At the moment, the memory tests are not bad, but quite bad. I would not like to talk about 'all' tests, but most of them are unaware of significant changes in the hardware. And the main 'harm' is not at all from memory, it has evolved little, namely, from the processor and memory controller (to a lesser extent). Processors have become faster, there are a lot of them and they have become strange. :) For example, before the memory 'sat' on one controller, with which the processor communicated. Now memory can hang on different processors and, as a result, have a different 'distance' from a particular processor core to a particular DIMM. In addition, the amount of caches in the processor has increased, which may affect testing. For example, TM4 used 512K test block size. At the time of writing the program, this was the optimum, but now this block quietly fits in L2 and the test does not work at all as intended. Will this unpleasant moment affect the quality of memory failure detection? Undoubtedly and in the most disgusting way. Alas. Other programs can operate on an access block, which is now extremely unreasonable and causes more problems than mythical benefits. Everything becomes obsolete. Alas, the same fate befell MemTest86. Quite good and effective, now it has quietly degraded to 'just a test'. The reason is the same - the test modules have not changed for a long time, and the hardware does not stand still. Alas. Other programs can operate on an access block, which is now extremely unreasonable and causes more problems than mythical benefits. Everything becomes obsolete. Alas, the same fate befell MemTest86. Quite good and effective, now it has quietly degraded to 'just a test'. The reason is the same - the test modules have not changed for a long time, and the hardware does not stand still. Alas. Other programs can operate on an access block, which is now extremely unreasonable and causes more problems than mythical benefits. Everything becomes obsolete. Alas, the same fate befell MemTest86. Quite good and effective, now it has quietly degraded to 'just a test'. The reason is the same - the test modules have not changed for a long time, and the hardware does not stand still.
However, if you read a horror story about testing problems, please :)
What's new.
Added full support for 16 tests and the ability to load other test configuration files. Unfortunately, a complete and imperceptible restart of the program is very difficult, so you will have to use the "manual" launch. After installing the new settings file, the program closes.
Appearance.
TestMem 5
In the program window, on the left, the type and name of the processor, its frequency, the number of cores and the supported SSE modes are displayed.
The right side shows the state of the system memory - how much is available and how much the program is busy with.
The middle left shows the progress of testing, when a failure is detected, cells 0-5 change color to red and the number of test failures is displayed in the status section in the middle right.
Small description.
This program is built on a slightly different principle than all the previous ones. Namely - it is customizable... Moreover, it can be configured by the user for those conditions that seem best to him. The program has the concept of 'test module' and 'test'. A module is called to perform testing, but it can (and should) be configured in different ways. Formally speaking, tests in S&M are one and the same module, but with different settings - have you seen that the performance of tests varies significantly? ... and this effect can be different for different memory (different manufacturers). Well, if the efficiency changes, then the logical conclusion from this is that by adjusting the parameters it is possible to raise it (efficiency, that is). It is difficult to consider a program that was written 5 years ago to be optimal. :) So, test = test module + individual settings. The second point is the number of test threads. In terms of modern processors, the number of testing threads should be more than one, which will make it easier (more precisely, more often) to communicate with processors with their own memory. This is especially true for the K10-11-12 with its distributed bus. The program supports a different (let's put it mildly) number of testing threads. From S&M's experience, I can say - the fastest mode for one process, but I have been repeatedly informed that enabling multiple mode, although it leads to a slight decrease in speed, increases the efficiency of the algorithm. Well ... although the speed of work is almost synonymous with quality (because a slow algorithm will not find errors), it is stupid to argue with practice. The program supports a different (let's put it mildly) number of testing threads. From S&M's experience, I can say - the fastest mode for one process, but I have been repeatedly informed that enabling multiple mode, although it leads to a slight decrease in speed, increases the efficiency of the algorithm. Well ... although the speed of work is almost synonymous with quality (because a slow algorithm will not find errors), it is stupid to argue with practice. The program supports a different (let's put it mildly) number of testing threads. From S&M's experience, I can say - the fastest mode for one process, but I have been repeatedly informed that enabling multiple mode, although it leads to a slight decrease in speed, increases the efficiency of the algorithm. Well ... although the speed of work is almost synonymous with quality (because a slow algorithm will not find errors), it is stupid to argue with practice.
At the moment, the following test parameters are planned (and supported):
  • block size. The smaller, the more efficient the algorithm. But, if the block fits into the cache, then the algorithm will fail.
  • block bypass method. Linear or bouncing. The first one has a high speed, the second one - more intensively loads the controller-DIMM bundle and leads to greater memory heating. (um, it's not for nothing that the fourth test in S&M heated up the memory so much).
  • the principle of generating templates. Constant, variable and random.
Test modules.
So far there are only two of them, but this is temporary.
1. Test 0, namely, and only on it this module works - data stability check. The idea here is that all memory is signed with some non-constant pattern, then testing is performed and the safety of this data is checked.
The test dramatically slows down the testing speed.
2. SimpleTest - although it is called simple, it is more sarcasm. All settings are supported (size-method-template), but not very efficiently optimized due to increased versatility. However, losses due to non-optimal software implementation are not so great and are leveled when multi-threaded testing is enabled - several processors clog the memory I / O channel by 100%. :) However, if something can be simplified, the speed will increase.
Feature: the program consists of two parts - a startup program and a DLL with test modules. Unpack everything and keep the directories.
Wrote two functions: MirrorMove and MirrorMove128.
The bottom line is that the test block is turned inside out. In this case, two processes of reading and writing go to meet. If the memory controller is trying to be clever and adapt to the access mode, then from such pornography its boss should be demolished - there are never two equal processes in + and in - addressing. The functions themselves only shake the block, but do not test data integrity. Test 0 is used for verification. Therefore, if you want to use these functions, do not turn off test 0.
MirrorMove
- mirrors the testing block. With an even number of reflections, the final state of the block does not change (if there are no failures). The block itself can be split into several subblocks and 'mirrored' simultaneously [/ i]. This creates big problems for the controller (and the memory itself) - more often you have to overload SDRAM pages.
Only Test Block Size and Parameter are configurable, which can take values 1,2,3,4 - this is the number of sub-blocks in the block.
All other settings (and this is the template generation mode) are ignored.
MirrorMove128
- similar to MirrorMove, but works a little differently - operations are performed on a page of 128 bytes (see below), an additional offset is made between access. Those. movement (mirroring) is done in stripes in several passes - first even stripes, then odd (for 2 stripes). In addition to increasing the load on the memory controller, this action causes an intensive page reload in SDRAM, which increases the likelihood of a failure in it. (well, heating, of course)
Only Test Block Size and Parameter are adjustable, which can take values from 0 and more. The Parameter itself means how much additional [/ i] should be shifted in pages of 128 bytes. Those. 0 will mean linear access (almost like in MirrorMove), 1 - skip page and jump 'every other time', 2 - skip 2 pages (256 bytes) ...
Accordingly, Parameter sets the number of additional bands (passes) to fill the entire block. Judging by the execution time of the move, then, for Core2 (probably, and other processors with the old interleaving mode) the 510 hour causes the greatest problems. This means that it is potentially interesting for testing. For other processors and systems, it would be good to check numbers in powers of two minus 2. This '-2' forces you to select not one, but two SDRAM pages, which causes an increase in time. That is, for optimization it would be good to check the row 128-2 = 126, 256-2, 512-2, 1024-2, 2048-2.
Regarding access to 128 bytes, this was done on purpose. As a rule, a data transfer unit on the bus is 64 bytes, which corresponds to a cache line, but in Core2 (and higher) this line is paired and its dimension is 128 bytes. If you read 64 bytes, the download speed will drop. In addition, in the new processors (AMD K10, K11 ...; Intel Core i *), interleaving is not lowercase, but block and 64-byte access unit. So when accessing 128 bytes, both DIMMs are read.
A further increase from 128 to 256 bytes is not yet relevant ... but you can do it. There will be MirrorMove256 :)
In TM5 version 0.5, the dimension of the presentation of the test test block has been changed. It used to be in bytes, now in megabytes. The argument is that small blocks are nicely cached in L2 / L3 and won't be tested. Meaning? There is no sense, but convenience suffers, so I changed it.
Because in modern processors the cache is more than 4Mb (or the order of that), then the numbers 0-3 are not interesting and they are interpreted in a special way. Namely, as the degree of window breaking.
Testing is performed in a 1Gb window (this number can be changed) and the test block should fit in it. You can specify the size of the test block in an absolute value Mb, or as part of the window. Here are the numbers 0-3 and define this 'part'.
0 = whole window
1 = 1/2 window
2 = 1/3 window
3 = 1/4 window
Probably, for the MirrorMove * functions it is better to specify 0 and give the whole window.
Customization.
After starting the program, the MT.cfg file appeared in the bin directory, which is the test configuration file.
Enable = 1 - 1 = enabled, 0 = disabled
Time = 100 - testing time, 100%
Function = SimpleTest -
DLL function name Name = bin \ MT0.dll - dll name
Pattern Mode = 1 - pattern type. 0 = constant, 1 = variable, 2 = random
Pattern Param0 = 0x1E5F - used to generate a pattern; For mode 2 serves as a multiplier
Pattern Param1 = 0x45357354 - similarly. For mode 2 is added to the template.
Parameter = 0 - the principle of moving by addresses.
Test Block Size = 4194304 - block size, in bytes
To generate a template in mode 2, a simple formula is used to obtain RND = Value * Param0 + Param1
Parameter is a way to go to the next block. 0 = linear (sequential) bypass. Other values are only for their DIMM. The number itself is how much to shift.
The idea is that first one DIMM is checked, then the second (and the third, for variants like Core i7).
Access unit, i.e. the number of bytes taken from one DIMM at a time 64 bytes. Accordingly, by setting Parameter = 1, the check will go on each block of the selected DIMM. If "2" - then after one .....
By the way, the section for setting up the equipment is important here. I think almost everyone has memory in paired slots and DUAL mode works. So you need to do one thing - switch the Intreliving mode . 0 for older processors (no integrated memory controller) and 1 for newer ones.
The memory manager in Windows 7 has one feature - as soon as you take memory from Windows, it immediately begins to empty more and more. Usually, it is enough to wait a few cycles and this process will calm down. If it interferes, then you can disable this 'soft' mode of memory request.
If you put: Capable = 0x 0 , then the occupied memory will be immediately latched.
TestMem support page - TestMem V
Excellent thread @munternet :)
That Cfg.link file seems to reappear everytime you run the program, but it is only the first time, or first time with a new preset, that we must delete it right?
10 cycles with single rank memory and 5 cycles with dual rank memory is still enough, or do people run it for like 100 cycles?
Edit : munternet could you fix the download links? Google Chrome thinks it is an email adress....
You get it all with one click ... look at pic from my post ...
Discussion Starter · #6 ·
Reactions: fuzzy_dunlop
Overclock the World
I think we should modify 1usmus_V3 to 20 cycles instead of 6
That matches with anta's 3 cycles config , where both take 1:30h for 16GB and logically twice for 32GB
6 cycles 1usmus_V3, doesn't find issues with tRFC and so also tREFI
Also any config taking less than 45-60min won't let memory reach thermal equilibrium :eek:
Yes, you can edit the cfg file and set that yourself.
Thank you for this. I didn't feel like puting 10$ for a memory tester like Karhu when you can get this for free.
Discussion Starter · #11 ·
If anyone can find a tutorial or read-me for this in English I will add it to the first post :)
Glad I found this thread, was annoying how 1usmus_V3 was stopping after 3 cycles.
Downloading & running the app from link in 1st post shows app running only 5 tests, is it suppose to do this with new conifg?
Iusmus_V3 had 15 tests.
What is the AWE module thing when loading TM as administrator ?
After running it the first time you need to reboot, then the AWE thing will go away. Remember to run it as Admin as well.
Hi. I'm running my memory with [email protected] using following timings:
My RAM Frequency is 1.45,
SOC is 1.1
Both DDG* are 1.05.
I passed Extreme1 Anta777 preset in TestMem5 (the 2 hours one) with no error. However I want to run my memory 24/7.
I don't turn off PC when I leave house or go to bed so I want to make sure that my parameters and values are optimal for safe use?
I don't know much about memory overclock. If someone could tell me if there is anything I can change / lower to make it safer and stabler in long term I would really appreciate.
Also can anyone suggest some super heavy preset for TestMem5 that I can leave overnight for 8-10 hours to make sure I don't have any problems? Anta777 2 hours doesn't seems to "enough" in my opinion. Yesterday my game crashed without any error (no error in event viewer either) so I'm not sure if its just a game or memory related.
1 - 20 of 116 Posts
