Memory timings,power supply or what?
265 3
I overclocked my cpu to 3.1ghz and it runs great.however.when i push it to 3.2ghz prime95 locks up after 2 minutes (
) and it rebooted while playing fear after about 10.My temps overclocked are fine(34 idle,40 load) and all my rails look stable(need to test them with a multimeter).Can anyone tell me what i need to do to fix this.
1 - 4 of 4 Posts
What steps have you taken during to overclock so far? Did you change anything more than the CPU frequency?
No. I have been trying to change my memory clocks but when i change the cas latency it wont boot windows.
Sounds like your vcore might need to be bumped up a little higher. I Would also suggest running just 2 dimm moduls instead of 4 for ocing. If you need 2 gig of memory then I would just get 2x1gig. Id try your vcore first bump it 1 maybe 2 notches higher
1 - 4 of 4 Posts
