Memory: Team Xtreme 16GB (2 x 8GB) 2400 (PC3 19200) Model TXD316G2400HC10QDC01
Motherboard: AsRock Z77 Pro3 (Supports up to 2800+(OC))
I set XMP Settings to XMP 1.3 Profile 1 (10-12-12-31 1.65V) and ran Memtest to find the timing was still the defaults of my Motherboard (8-9-9-24), even though in the BIOS it says "XMP 1.3 Profile 1 10-12-12-31" ... but when I go into DRAM Configuration, I see everything is set to Auto and the only way to change them in this page of the BIOS is manually, even though I set the XMP Profile already, that doesn't work.
I believe I am going to need all the correct XMP timing values not just the first 4:
CAS# Latency (tCL) 8 Auto
RAS# to CAS# Delay (tRCD) 9 Auto
Row Precharge Time (tRP) 9 Auto
RAS# Active Time (tRAS) 24 Auto
Command Rate (CR) 2N Auto
Write Recovery Time (tWR) 14 Auto
Refresh Cycle Time (tRFC) 235 Auto
RAS to RAS Delay (tRRD) 7 Auto
Write to Read Delay (tWTR) 7 Auto
Read to Precharge (tRTP) 7 Auto
Four Active Window (tFAW) 23 Auto
CAS Write Latency (tCWL) 8 Auto
ODT WR (CHA) Auto (60 / 120) Auto
ODT WR (CHB) Auto (60 / 120) Auto
ODT NOM (CHA) Auto (20 / 30 / 40 / 60 / 120) Auto
ODT NOM (CHB) Auto (20 / 30 / 40 / 60 / 120) Auto
MRC Fast Boot ENABLED (Enable / Disable)
I've entered the first 4 numbers (10-12-12-31) but I still can't budge past 1800 MHz not even 1866, so if changing those numbers so drastically (from 8-9-9-24 to 10-12-12-31) will not allow me to change the speed at all, then I think I need the rest of the timings I mentioned above.
I have no idea why the XMP settings wont load, but I wished there was some way to find out what the other timings would be in the XMP profile.
Can anyone help me?
Can anyone help me?
