Hmm... you want it to run with a divider? With 2.8v of vdimm you should try running it async with the CPU (400Mhz, or 1:1 for your ram). If you can't get OC you want, then try using a divider, but try loosening the timings first. You'll get a better performance with loose timings than with a divider and tight timings.
