1 - 17 of 17 Posts
hi
I got Asus Sabretooth P67 motherboard and OCZ Obsidian 2 x2GB DDR3 PC3-12800 RAM
for some reason i cant get the RAM to run on 1600Mhz
when i open Asus AI suite it shows 533Mhz that times 2 = 1066Mhz
i tried setting freq in bios but it wont matter AI Suite still shows 533mhz
can any one help me?
here ya go
cpu-z says dram freq 800 mhz?
that means i am running on 1600mhz?
mah i tought AI suite was a reliable source
how about tempratures
BIOS shows i am at 55C idle thats pritty hot :/
tho AI suite shows 30 at Idle
Discussion Starter · #9 ·
core temp shows idle 27C :O
so its safe to say that i can OC my setup?
Discussion Starter · #12 ·
ok i heard something about the EFI causing the cpu to run hot when in BIOS
guess thats a normal thing
any suggestions on how i should OC my Core I5 2500K?
Discussion Starter · #13 ·
what the
when ever i start prime95 the Tempratures in Core temp jump from 30C to 60C instantly
im uzing large FFT test is this normal?
Originally Posted by klote2314
what the
Yes, are you using the stock cooler?
Prime95 blend is the best test for Sandy Bridge CPU's at the moment.
Discussion Starter · #15 ·
no i am using Corsair H50...
it should not just go that high im reaching 66C when i keep it up >.>
fairly high for an H50... I would check if it's properly mounted
Discussion Starter · #17 ·
mah guess i need to go buy some arctic silver cooling paste
im going to have to remove the motherboard again T-T
1 - 17 of 17 Posts
