1 - 5 of 5 Posts
Hi Guys<br />
<br />
I'm getting an error in Memtest after about 65%. My timiings are 3-3-2-5 1T @ 272mhz using 2gb Corsair XMS 4400 Pro.<br />
<br />
My question is..........would a touch more volts steady them out? They are stock 2.8v at the moment, would 2.9v be safe?<br />
<br />
Ta
You could try 2.9v to see if that stables things out. If it doesnt you may have to lower down your overclock a bit. I would set everything to stock to check whether it is the ram that is bad or whether it is the overclock.
I just ran Memtest with 3-4-4-8 1T and it passed 100% without an error. <br />
<br />
I think 3-3-2-5 1T at 272mhz was a bit ambitious!
Was a bit <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /> <br />
<br />
No harm in trying.
Discussion Starter #5
I'll try and tighten them up again later <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
1 - 5 of 5 Posts
