1 - 4 of 4 Posts
Old school
For me, 1.
Others will probably say more, but it'll just re-start the test after you passed so I don't see the need in that...
well I had a questionable module and i put it in this morning and when I got home from work, it had completed 14 passes. Safe to say its fine?
On the second stick now, it's done with its 6th pass.
2 more to do.
Iconoclast
One, if you are just testing if a module works or not.
For testing OCing stability, you'll need many more, as well as other tests.
1 - 4 of 4 Posts
