1 - 7 of 7 Posts
Just wondering how long it takes to run memtest86? Does it just keep going or does it actually end eventually?
Thanks
The rule of thumb for most of us is to run test #8 (my opinion) or test #6 and if it passes around 20 times with zero errors then you're stable.
thanks guys
I love this forum for quick responses
From ncsa's post ... a good quick test.
http://www.overclock.net/faqs/38169-...roduction.html
Memtest:
For any change it is recommended that you use Memtest to check if this configuration is stable.
Some quick checks using this tool are:
Get your Memtest CD - make sure CD boot is prior to HDD in BIOS.
Boot system with CD in drive - Memtest should auto run and for 10-20 loops make sure that these key tests are OK - 5, 6, 8
Once running, to select Test #5
Type C 1 3 5 <enter> <enter>
Now Memtest will loop in Test #6
And for Test #6
Type C 1 3 6 <enter> <enter>
Now Memtest will loop in Test #8 (20 loops best)
And for Test #8
If you get errors in any of these tests you will need to recheck you BIOS settings, timings and / or voltages. There is no silver bullet here as each system is different and will react & perform differently - time and patience is required
im trying to use memtest86 and it just wont boot up. i dont have a floppy drive so i burned the .iso file onto a cd, set cdrom as my 1st priority, but when it comes time to boot from it it just skips over it and continues booting windows. any ideas?
1 - 7 of 7 Posts
