1 - 5 of 5 Posts
Hello.
I was wondering, why won't Windows let me merge two spaces marked as Unallocated?
Shouldn't those two unallocated parts be just a big one? Any help of how to merge them would be appreciated, thank you.
Windows Wrangler
Originally Posted by Phenomz View Post
Hello.
As billbartuska said.
  1. Now is your chance to extend (or shrink) D: to the size that you really want (or leave it alone if you actually like it as it is).
  2. Create a new partition in the space between D: and F:.
  3. Move the files from F: to the new partition you just created.
  4. Delete the F: partition.
  5. Create a partition in the free space of the drive, which will now be combined at the end.
There you go! Really helpful, thanks to you both, got the "issue" solved.
1 - 5 of 5 Posts
