1 - 3 of 3 Posts
To remove the Raijintek logo without harming or marring the Metis case, simply:
1. Gather a Q-tip, a paper towel, and bottle of fingernail polish remover.
2. Dip Q-tip and gently scrub the logo with it. The logo will immediately begin to dissolve, so use the paper towel to dab the paint away while it's wet. The remover evaporates nearly immediately, so work quickly.
3. You'll need to dip the other end of the Q-tip into the remover again to clean up any remaining residue.
4. Once removed, clean the front of the case by spraying with eyeglass cleaner, and wipe with a paper towel.
There will be no evidence of a logo ever being there!
Eh, Wha?
Nice. Good tip even though I don't own the case. Makes sense but I'd personally have been scared to try - you never know if it'll wipe away the color on the case as well.
1 - 3 of 3 Posts
