Mice cable pin arrangement and internal connector size - database
176124 211
This thread is about information you need to replace or exchange your mouse cable.
You will find required informations:
  • connector size
  • pin (color) arrangement
  • video tutorial (down below)
The connectors with the same size are compatible to each other.
The most common connector is called "JST 2.0 PH 5-Pin".
Dimensons: length 10.5mm, hight 7mm, with 4mm
Later called "Standard Plug"
A smaller connector variant is the "JST 1.5 ZH 5-Pin".
Dimensons: length 9mm, hight 6mm, with 4.8mm
"JST 1.25 GH 5-Pin".
Dimensons: length 7.5mm, hight 5mm, with 4.15mm
Size reference picture:
from left to right: Logitech G9(x), Steelseries Rival, Logitech G500, JST 2.0 (nearly all other mice)
The internal plug contains 5 cables with crimps. This cables connects your mice with the USB port.
It contains:
black - ground
green - data+
white - data -
red - 5volt
thick black - shield (could also be yellow for some kind of "shield")
View for the pin arrangment: you look at the 5 plastic snaps and the cables coming down out.
Standard plug JST 2.0:
G-Wolves
shield
white green black red
Skoll, 302
Endgame
shield
black white green red
XM1
Redragon
red white green black shield
until yet, every model
Glorious
shield
black green white red
Model O
Nixeus
shield
Revel Fit, Revel
Zowie
shield
all Zowie mice
Corsair
shield
Harpoon RGB
TT eSPORTS
shield
Ventus R optical
Roccat
shield
Kone Pure Optical / Military
shield black white green red
Nyth, Kone Pure Owl-Eye, Kone Pure EMP
red black green white shield
Kone Aimo
red black shield green white
Burst Pro, Burst Core
Logitech
green white red black shield
G203, G102, G Pro, G100s, G300s, G302, G303, G402, G403, G502, G400, MX518, MX500, MX310, MX300, G1, G3
Logitech G600
Asus
ROG Sica
Ninox
Venator
shield black green white red
Aurora
Razer
shield
Deathadder, Deathadder Chroma, Naga Trinity
Viper Mini, Mamba TE, Lancehead TE, Basilisk, DeathAdder Elite, Abyssus 2014, Razer Pro Solutions v1.6 (probably DiamondBack too)
DeathAdder V2
Naga Molten, Naga Hex, Naga 2012, Lachsis
white green black red shield
Imperator
Steelseries
Rival 106
Sensei
Sensei 10, Rival 100, Rival 110, [RAW] Frost Blue edition
green white black red shield
Kana2, Kana?, Raw?
Kinzu
red green white black shield
Xai
Microsoft
shield
Intellimouse Optical 1.1, IntelliMouse Explorer 3.0 (MLT04), WMO (if the connector is removable)
IntelliMouse Explorer Pro (3389), Microsoft Classic Intellimouse (2017)
Mionix
shield
Avior, Castor, Naos, Naos QG
Cooler Master
CM Mastermouse S
MM710, MM711, MM720, CM MasterMouse MM520/MM530
CM Storm Recon
Genius
shield
Genius Maurus GX
Dreammachines
shield
DM3 Mini
DM1 Pro
Finalmouse
UL2, Air58, Ultralight, Scream One
Motospeed
Xtrfy
M1
shield red black white green
M4, M42, MZ1
NKEY
shield
007 mini, G312
Cougar
Revenger S
ABKO HACKER
shield
A660
Non standard plug JST 1.5:
Roccat
shield
Kone Pure Ultra
Razer
Viper, Basilisk V2
Deathadder V2 Mini
Corsair
Scimitar
Asus
Gladius II Core
Logitech
G500
Non standard plug JST 1.25:
Roccat
black white green shield red
Kain Aimo 12x
Steelseries
Rival, Rival 300, Rival 310, Sensei 310
Corsair
M65 Pro
MadCatz
shield
R.A.T series
(older cables might have a blue instead of the red cable)
Non standard plug JST [size smaller than 1.25]:
G9, G9x
Video tutorial- instruction on swapping the pinout
This thread will be edited with more information. Feel free to post information that is missing here.
1 - 20 of 212 Posts
Nice thread. Maybe some more info about size differences and compatibility. Standard plugs should all be compatible, right? Assuming you match their color. The g9x has the smallest plug i've seen I'm not sure if any other mice use it(besides the g9?) Second smallest I have come across the g5/g500 cable and they can be interchanged.
Thanks for the thread, very helpful! At least for me, who makes paracord cables
Also, some additions, all of them standard JST 2.0:
Logitech G600
Razer Pro Solutions v1.6 (probably DB too)
CM Storm Recon
Genius Maurus GX
shield white green black red
I'll post if I know more
Clown cursor
Burned my friend's kinzu v1 because of the wrong pin arrangement here T_T (and because I'm ******ed).
Please edit the topic to prevent such cases in future.
red, white, green, black, shield
1 - 20 of 212 Posts
