1 - 8 of 8 Posts
Discussion Starter #4
Originally Posted by Weedmancz View Post
What brand would u recommend for for water blocks?
anything BUT EK lol
but unfortunately EK is the only WC company that does a wide range of mobo blocks.
MIPs might have a block for you though; I'll help you check right now
edit: I don't believe that they do.....so you'd be SOL in this case damn.
Originally Posted by superericla View Post
I've used an EK EN block on my 6970 for months now without issues.
dealing with EK has left me with a bad taste in my month. I will not buy anything new from EK anymore; however as Ceadder said before I'd be happy to buy any EK stuff 2nd hand from OCN members just to support them
Originally Posted by Peopie View Post
I think xspc makes some motherboard blocks
I'm not sure if they make one for your mobo though...
I doubt it; XSPC is still a relatively new company that had success after its Rasa WC kit and CPU block.
as far as i know; EK is the only company that makes a wide range of mobo blocks.
1 - 8 of 8 Posts
