kinda crap specs and the RAM isn't upgradable but $59 ¯\(ツ)/¯Intel Celeron N3450
Intel HD Graphics 500
4GB LPDDR4-2133 RAM
64GB ROM
https://www.reddit.com/r/linuxhardware/comments/tk6hdp/_/ie4mjydYou should be able to remove the LTE module. And put a 2242 ssd in it. Or mod in a bigger one.
That is what i would do. Because it might not fit double sided 2242's. And i haven't been able to find single sided 2242's larger than 64gb.https://www.reddit.com/r/linuxhardware/comments/tk6hdp/_/ie4mjyd
https://www.reddit.com/r/linuxhardware/comments/tk6hdp/_/ieein66
if the EMMC is terrible (probably is) I'm going with a 2280 🙃
someone from that same Reddit thread said this 2242 fit/worked, only 120GB though.That is what i would do. Because it might not fit double sided 2242's. And i haven't been able to find single sided 2242's larger than 64gb.
better a liar than a dumb Avacado
It never goes over 10w without that in my testing with cinebench. I have the v2.it's unlocked in the BIOS already, just change it there
This is looking more fun by the day
