1 - 20 of 22 Posts
Hello, After searching and getting more information about the mouse, i actully want to get it before get the ikari also.
how many mouse versions the 3.0 have?
theres a version of proven shape? I'm mean- the feeling of the metrialls?
or maybe version of fixed scrollwheel?
can some one link'ing me to worldwire's delivery online store that selling the mouse?
thanks.
Sadly, I don't think there is a version of the MS3.0 which has the mousewheel fixed. You'll have to mod it or live with not jumping with mousewheel. I'd avoid the glossy Chinese versions and just get regular one:
http://www.dansdata.com/images/blog/meeces1280.jpg
Either of those two are fine. I must note too that the side buttons are very loose.
The link to the mod is here in case your interested:
http://www.cybergamer.com.au/forums/thread/166796/HOW-TO-Fixing-scroll-wheel-on-Intellimouse-3.0/
I opening the mouse is nothing to be scared of and is very easy.
Gone
To be honest, I wouldn't recommend buying the 3.0 respawn. The overall quality has gone down hill since they stopped producing the x06/x08 models back in 2006. Granted, the sensor is the same, the new model feels much much cheaper.
The 1.1 on the other hand feels like the classic.
Gone
Originally Posted by avinin1;12021280
well, if you dont recommended and if I dont wrong, you tested "modren gaming" mice, so why you use them? ><"
just want to know really..
Because I had an x08(2005) till it broke around 4 months ago. Granted, I bought both the respawn and legends editions, nothing felt as good as the original.
To rate: Any 3.0 prior to 2006 (SE/JP/CN/Normal)>Legends (2010)>Respawn (2007).
I'm currently using IMO1.1's I bought in bulk from china.
Gone
Originally Posted by mrwalker;12021839
My understanding is that this IME 3.0 has the mouse wheel fixed: Amazon.com: Microsoft Intellimouse Explorer 3.0: Electronics and the DPI on the newest one from Microsoft has a DPI of 450 and not 400 from what I've heard. I don't have it so I can't confirm.
It's not fixed yet, I can confirm this with a 2010 Legends.
Also, my older x08/2003 WMO tracked the same distance as the respawns. I don't know where the whole 450 DPI thing came from, Microsoft's spec sheet still states 400.
Skylit, can you tell us where you get the 1.1's i bulk at? :]
Or is it a secret?
Gone
Originally Posted by foppa;12026261
No the Zowie mice are 3.0 revisions....even the EC2 has the same shape, just smaller.
The link was to a zowie Intellimouse optical 1.1
Originally Posted by cee;12020781
Zowie has came up with revision of IMO 3.0 I believe. Have a look, reviews say they are decent.
Link
Or is it a secret?
Ebay seller lol
Discussion Starter · #19 ·
well, after searching alot at ebay - there no really trace of the oldest 3.0..pretty rare Like you've said.
so Ill buy the legned version, you've said that is better than respawn..
what the diffrence between them all really? ><"
Gone
Glossy top, doesn't wear out as quick.
Matte rubberized side buttons feel slightly stiffer and less cheap. (They still don't compare to the original
1 - 20 of 22 Posts
