1 - 4 of 4 Posts
So, this is going to sound a little bit weird, but I am looking for a mid tower case with the motherboard tray far enough away from the side panel that I won't have to force that side plate shut....I have to do that to my current case, what with all my cables hanging around all ghetto in there....
I was going to get the evo tempest, due to ability to hold both 280 and 240 rads, but i found out that the side panel has to be forced shut.
Secondarily, I want to be able to put a dual radiator inside the case....
so, to recap: Non-forced side panel, dual rad (240 or anything else is fine).
I suppose a single 200 would be fine, too.
Any suggestions?
Carbide series and the 600T both have a *ton* of room in the back panel to close with no prob. Was a big adjustment to my Arc Mini coming from a 600T, definitely one of the best things about the case.
With the 600T, you can put a dual rad up top and a 200mm rad in the front if you want GPU + CPU.
thanks guys!
for cost concerns, i think i will be going with the 500R.
+repped both.
1 - 4 of 4 Posts
