See, you will need three things before you start a foam dam around the GPU and CPU and some conformal coating on the electronics around them and kapton tape to make it actually safe for daily usage.
It will work with your current cooler but expect damage with time even if its copper as this eventually happened with my GE75.
Now if we are being realistic I would recommend just repasting with a good paste clean the fans and undervolt the CPU and have a curve for the GPU, now the problem is I have been using kryonaut but expect two things first it has major pump out problems at high temps and low durability (Expect to change for sure under a year and sometimes after 6 months) so you will need to look around on what people are recommending for laptops these days.
I have an undervolt of -125mv on the 10750h and a curve at 875mv on the 1660ti which makes me comfortably play at mid 60s on the GPU and mid 70s on the CPU ( Use coolboost and raise the back of the laptop for it to get intake)
