1 - 3 of 3 Posts
Lurker
I randomly decided today to search for a mini AC and found http://www.amazon.com/Small-Fan-Mini-Air-Conditioner-convenient/dp/B002F8IFV6. It's powered by usb or batteries. I was wondering what would happen if I placed one of these next to my H60 Radiator (sucks in air from the inside of the case) or below my Asus 6870 DirectCU. This technically would cool the inside of my case and provide the fans with cold air to blow at the radiator or at my vga heatsink. I might try this to see if there are any significant changes in my temps. Please list any flaws to this so I don't spend the money for no reason. Thanks!
Not New to Overclock.net
Its a piece of junk?
Improve the airflow in your case instead or lower the ambient room temperature. If your temps are bad enough, you might consider liquid cooling.
That is just a miniature swamp cooler. If you want to lower your incoming air temperature, put a window air conditioner in your room.
1 - 3 of 3 Posts
