1 - 8 of 8 Posts
Hows this build, and will I be able to play media without issues with this mobo and cpu? It will be used for media only if I get it, which I doubt will be any time soon.
Things I want it to be able to do:
Play movies from hdd without issues
play movies from dvd
play music
run itunes
ect.
MEDIA!
Build:
Comments?
Your proposed build will let you play DVD/AVI files.
Couple things
for a HTPC, might wanna go with the 1TB WD Green drive.
http://www.newegg.com/Product/Produc...82E16822136317
As for motherboard/cpu/graphics
http://www.newegg.com/Product/Produc...82E16813500021
http://www.newegg.com/Product/Produc...82E16819103255
motherboard even comes with wifi.
or if you wanna stay with Intel:
http://www.newegg.com/Product/Produc...82E16819116069
performance is slightly worse, and slightly more expensive.
the IGP and CPU will offer much better performance, letting you play blu-ray/HD content over the Atom and Geforce 6200
and just better performing ram worth the few bucks more:
http://www.newegg.com/Product/Produc...82E16820231087
Overclocked TI-83
I'd go for something more powerful than the Atom. I have one, and it stutters on 480p video from Hulu.com.
Originally Posted by Sullivan
hmm...
I don't know about that mobo, it doesn't have a PCI slot for extended graphics...
The IGP is good enough until something else that requires higher system resources than Blue-Ray comes out.
Another option would be to go with the Jetway JNC81-LF for about $50 more. It comes with the 780G (HD3200), and has an HDMI port - if you need that.
NewEgg has G.Skill DDR2 800 memory with free shipping for $2 more than your list...
1 - 8 of 8 Posts
