I have finally got the parts for my new build
AMD Phenom x3 8450 CPU
Asus M3A78-EM Mobo
A-Data 2GB 1066+ Extreme edition RAM
Wester Digital Caviar Blue 250GB HDD
Fortron High Efficientcy 400W PSU
Of cource this thread is useless without PICHERZ!!!!
That one is the cork tree board to which i will attach the build......untill i will get a proper case.
Next, opening the motherboard box.
Well looky here. The motherboard.
Took some time to attach it to the cork board, but here it is, with the CPU in...
Connected to the PSU, HDD and RAM installed and in place.
That was the moment, when i realised the PSU didn't have a power cord...
EDIT: Ok, so i have the power cord now. I can finally plug it in....BUT(!) i have to reaarrange my room to put the GIGANTIC CRT(if you're still reading Andr3az) screen near the build. PIC: i just reallized, that the cork board is the easiest moddable case(
) i have ever seen.
To be continued.
UPDATE!!!!!!!
My build hase come through with some changes, some minor, some more than that, so without further delays i present: my PC
As you can see i got a case, which is a bit old, but at least it's not grey going on yellow...
I also got a proper screen. It isn't much, but it is better than that old blur of a CRT...
And here's the case. Sorry for the bad camera work... As you can see i got a GPU, an Asus 4830 to be precise. I like it and don't forget, it's a budget build. Other upgrades include an AMD Phenom II 720BE, which i succesfully overclocked to 3,5GHz, some case fans, blue LED's and tumbler switches on the front of the case to controll the fans.
I also got a greenish acryl side-windows, which is just an acryl plate stuck with duck tape to the place where a case wall should be. Also, it doesn't cover the entire wall so there is an inch gap at the front. What?! That helps cooling.
Einsteinium - that's what i call it now.
I guess this is as much as i can tell you for now...
Thanks for reading and i would be happy to get some feedback
Asus M3A78-EM Mobo
To be continued.
UPDATE!!!!!!!
