1 - 8 of 8 Posts
I recently built a few cheap rigs for my niece and nephew. In my nephew's build, I used the i5 3570k. With stock cooling it idles at 15 degrees. I thought something was wrong, so I started testing. After three hours of testing, I couldn't find any problems, it seems to perform as it's supposed to. However, after three hours of being stressed, it was only at 40 degrees. The ambient temperature for the room is about 27 degrees.
So now, we're left with two choices: Return it for a replacement, as something might be wrong with it, or see how low we can get the temperature, and then start overclocking from there.
Any advice or wisdom from anyone with a similar experience would be greatly helpful.
· Premium Member
What are you checking the temperature with? Some programs report a "package" or "cpu" temp that could be anything. Check the actual core temps with either Coretemp or Realtemp and see what you get.
I've checked with Coretemp, RealTemp, and CPUID's HWMonitor. All say the system runs cold. I always check with a few different programs if I think something might be wrong, just to be safe. One program being wrong is believable. Two is unusual, but possible. Three is a pattern.
That's excellent that it runs cool!
However, there is no way that the core temp can be cooler than ambient temperatures, but that is no reason to worry. From what I have read, there is a big variation in the calibration of temp sensors. Since the temperature is actually found as a distance to Tmax (105 C), the further away from Tmax you are, the bigger the error. What that tells you is that idle temps are rarely accurate, but load temps will be more accurate. But, that load temp also sounds especially low - what program are you using to create a load situation? Most people here use the program Prime95 as a benchmark for load temperature. Also, what sort of cooling are you using?
At any rate, I don't think there is any reason to return it based on it reporting low idle temps. You have lots of overclocking headroom regardless, so I wouldn't worry about it too much
Originally Posted by richie_2010 View Post
well then you have a good chip, why return it.
theres clearly something wrong here, no chip can idle lower than the ambient without extreme cooling. this has nothing to do with being a good chip or not
Edit: it is physically impossible for the cpu to be lower than the ambient temp when using air cooling. your sensor must be wrong, even if software all says its the same, the the sensor is at fault, not the software..
Idle temps don't matter. Those temps are normal and they get hot. I don't know what kind of cooler you're running and it'd help if you post your system specs so we can help you instruct what you wanna know.
As for temps it's the load temps that matter.
We're here to help you in OCN if you need help. Welcome to forums.
Discussion Starter · #8 ·
I was using Prime95 to stress it. What got my attention was that it idled low, climbed strangely, then topped off pretty low when stressed. It was on the stock HSF.
That's exactly what I was worried about. I decided to return it, should have a new one sometime soon. Better to make sure the sensors work before we start on making them go up.
1 - 8 of 8 Posts
