1 - 14 of 14 Posts
The Computer Guy
reinstall windows
The Computer Guy
Originally Posted by DiNet
Don't reinstall. You can just repair.
that repair crap never work for me,just quicker to do a fresh install
Originally Posted by TiagoTheNerd
I Havn´t even installed, What i do?
EPIC.
Install it? Quite simple...
Win7 repair does work if you have isntalled win7 and after reboot it shows this msg. Takes about 2 min. to do the job.
The Computer Guy
when system boots up,go in to bios and change first boot to cd-dvd rom,then reboot with windows disc in drive and boot from disc.then start to install windows
The Computer Guy
kk,and gl
The Computer Guy
once you get windows completely installed then,u can go back in the bios and set 1st boot to your hard drive
1 - 14 of 14 Posts
