1 - 5 of 5 Posts
Old Timer
You dont need to use all the screws if you dont have them. Just make sure that the board is supported anyware you might be pushing on it (around the PCI slots, DIMM slots, IDE plugs, etc.)
As for your second question, "bump" simply means a post that is used to "bump" the post back up to the top of the listings.
1 - 5 of 5 Posts
