1 - 8 of 8 Posts
Can i run a mobile socket 754 AMD64 in a desktop
I know its possible with alot of others but i heard theres a trick to running them in a desktop
I think you just gotta setup your bios properly..
My 3400+ DTR booted up at 800mhz and 1v vcore..
I just kicked it up to 1.5v and 2.2ghz
u can run them fine, alot of guys here have mobile 64s in their desktpos like Yiffy and Xavier.
the best mobo for them is probly the DFI lanparty UT 250gb
sometimes it starts at only 800mhz, but u just bump it up to the regular running speed. otherwise, its the same as a normal A64
Would the mother board type matter?
i was thinking of an MSI or ASUS
but would a lan party be better?
yes it will run fine and you will get massive overclocks (with the rite coolin), get the dfi lanparty nf3 250gb mobo
^^^they are correct, the DFI is the best of the 754 boards and is only 105$
1 - 8 of 8 Posts
