1 - 5 of 5 Posts
Originally Posted by Patrice Mersault
My MOBO says it needs a 24-pin connector. The specs for my PSU are "20+4-Pin". What does this mean? Is it a 20 with a 24 pin adapter? Will this work fine on my MOBO?
Here's my MOBO:
http://www.newegg.com/Product/Produc...82E16813131569
Here's my PSU:
http://www.newegg.com/Product/Produc...82E16817148010
It means that it has a 20pin connector and also a 4pin 12v connector. If you read the reviews on that link you provided there is people that had the same question as you and they confirmed it's a 20pin after they received it.
You can get an adaptor, but you're probably better off getting a 24 pin PSU. I saw an adaptor setup blowup awhile back, it took the motherboard and a few other things with it. Maybe it wasnt the adaptor's fault, but I just cant trust it after that happened.
Great to know now, after I ordered the parts. I posted my build here and on another forum, asking to be critiqued. Apparently no one caught that problem. (edit)
Sorry to hear that
My reply...
What about the CONCORD I linked to? That has 34A on the +12V. That's solid, yes? I should expect little fluctuation with that.
Good spec on the 12v for sure... I'm just not firmiliar with the brand.
Yesterday I received a Sunbeam NUUO 550, very good specs, excelent reviews ... $80 at xpcgear
1 - 5 of 5 Posts
