Agreed, the next couple of months should be good for AMD. There are some new chipsets coming out for AM3, so you might try to hold out for a bit longer.
If you want, you can pick up the 720 BE right now, and use that in an existing board for a while. Personally, I'm not gonna get a new board for my rig until they come out.
so i dnt know if i should use 2 or 3 memory stick on it cuz i have the
JetWay JHA07-ULTRA-LF AM2+/AM2 AMD 790GX HDMI ATX AMD Motherboard - Retail
and the amd2 x3 already set to buy but im not quiet sure how much ram i wanna run
Dual channel ram works best in pairs, and OCin with only two dimm slots full usually allows a higher ram OC.
I would get a 2x2 gig kit of DDR1066. Most of those kits are $40-70, and will do just fine for you.
get the Asus M4A79T Deluxe seen some good reports about it, I have the sister board the DDR2 model it rox very stable and bios options for the Ocing fun
the Bios seem stable as well.
Overclock.net
