1 - 8 of 8 Posts
DFI NF4-D or -DR series
Unless you are looking to Sli later.
Originally Posted by Firefly
Whats a good OCing Mobo that will fit my specs?
You're not going to get much of an OCing increase with any motherboard out there. You'll gain more options with a DFI, but it won't help much in your OC. If you look at this review, you'll see that the MSI was right behind the DFI and your MSI board has identical OCing performance to the SLI Platinum. I suggest spending your money on something else or simply waiting for a future upgrade. IMO, this would be a complete waste of money.
http://anandtech.com/mb/showdoc.aspx?i=2358&p=21
Agreed
The only reason to ditch that board would be if you wanted to go SLI
Discussion Starter #6
I know But for some reason , I can't get an OC out of this one, Read other forums and some NEO4 have an OC problem of not getting over 240
Originally Posted by HardwaterH4ck3r
With that with the DFI ultras, you can do a little chipset modification that will enable sli.......
That doesn't work on new boards
1 - 8 of 8 Posts
