Mobo replacement for Foxconn BlackOps?
256 Views 4 Replies 4 Participants Last post by  ashblk
Is there a motherboard out there that has the capability of replacing my Foxconn BlackOps, while being around $200?
The support team for the BlackOps is horrible and it seems like Foxconn left BlackOps and moved on to BloodRage.
The BIOS it has is horrible and are all Beta..
Or should I just keep this board? I might appraise and sell. Only used twice too since I bought it.
http://www.newegg.com/Product/Produc...onn%20blackops
$289.99 on Newegg new.
1 - 5 of 5 Posts
IF you decide to get rid of it I'd go with an evga or asus board. Evga has excellent support if that is what you are concerned about. http://www.newegg.com/Product/Produc...82E16813188040 or http://www.newegg.com/Product/Produc...82E16813131344 for asus.
UD3P go check it out. You will max out your CPU and RAM before you max out the MB itself Go check reviews, it spanks all s775 MB as far as OCing, price for performance goes.
Not interested in the Gigabyte, despite it being a great and cheap board.
Wow the 790i dropped a lot in price... how is the overclock ability compared to the BlackOps?
Wonder how much this board is worth on OCN.. :\\
1 - 5 of 5 Posts
