You can run the linked RAM. The "extra" speed (difference between DDR400 and DDR500) will just give you additional headroom for overclocking. You may want to check to see what the maximum voltage your motherboard can supply to the RAM as some of the reviews on Newegg indicate that the RAM is a bit voltage hungry.
